587,704 active members*
3,547 visitors online*
    Apr 2020
    Syntec 6MA Z axis help
    Hi all need some help, we have a Syntec 6MA controlled CNC and trying to be able to set z height to material surface per job
    1. lower z axis to material height
    2. apply machine coordinates on that axis - (xy axis work this way but not z)
    but it gives me a negative value in the G54P1(G54) setting and it alarms out if trying to run job,
    but if I set the height manually in the G54P1(G54) to material thickness it works
    is there a way to use apply machine coords
    thank any help greatly appreciated
    Apr 2004
    5750
    Re: Syntec 6MA Z axis help
    What happens when you set it to zero?
    Andrew Werby
    Website
  1. CNC Syntec 6MA
    By badeninshao in forum Chinese Machines
    Last Post: 04-11-2021, 04:19 PM
  2. X Axis First Negative Software Limit Reached - Syntec 6MA
    By cripk8 in forum Chinese Machines
    Last Post: 08-02-2019, 06:26 PM
  3. Syntec 6MA
    By VDCabinets in forum Questions or Problems
    Last Post: 05-24-2019, 04:14 PM
  4. syntec 6ma
    By arzuklndr in forum Okuma
    Last Post: 04-03-2018, 09:53 AM
