588,507 active members*
5,079 visitors online*
Results 1 to 8 of 8
    Dec 2004
    4
    Question Linear Bearings for CNC Router
    I am sure this is one of the perennial beginners questions you experts get sick of, but what is the most appropriate linear bearing for a low cost CNC router? Reading the forums the options seem to be:
    1/ Plastic bush.
    2/ Four 90 degree opposed ball races on some sort of home made mounting assembly.
    3/ Simplicity bearings or similar.
    4/ Recirculating ball slides on hardened shaft.
    1 and 4 can be discarded due to too much friction and two much cost respectively.
    If well designed and built 2 should be OK, but a lot of work.
    3 seems OK but given that a 3 axis machine will require 12 slides at about $30 a pop its still somewhat expensive.
    Is this about right? Have I missed some option?
    Murray
    Either rollerblade bearings on some type of home made guide, or tubing, is what most people go with when cost is the biggest concern. Otherwise, Ebay for good quality stuff. But that might not be an option for you due to your location.
    Nov 2003
    634
    Don't forget about ball bearing drawer slides. Properly mounted, these can give great results
    May 2003
    323
    Linear Bearings
    Dear Sir:
    If you would Email me, [email protected], I will be happy to send you photos of my approach to bearings for a router. I made my machine as a test bed for a controller I am working on, but the ideas apply to a larger machine.
    Regards,
    Jack C.
    Mar 2004
    190
    jcc3inc, why not post the photos here? this way all of us will get the idea
    /F
    Sep 2003
    226
    Yup, you are right; it is a perennial question
    Here is a page I put together a while back that addresses a few low cost options.
    http://solsylva.com/cnc/cnc5.html
    Good Luck!
    Nov 2003
    634
    sol, very informative. Thanks for the link.
    T
    Oct 2003
    593
    Quote Originally Posted by sol
    Good Luck!
    I love your website. The second machine is a great piece of work, but the first one you made was fantastic. I love that dust collector cup and coat hanger limit switches.
    It just goes to show that a good imagination and the ability to make stuff from what we'd usually throw away, are more important than a large budget. Hats off to you. Nice work, and thanks for sharing.
    Regards Terry.....
    http://www.terry-is.f2s.com/
  1. Need help on linear bearings
    By bbergami in forum DIY CNC Router Table Machines
    Last Post: 05-26-2004, 12:04 AM
  2. Nylon Linear Bearings and shafting
    By Jcadwell in forum Community Club House
    Last Post: 04-15-2004, 02:29 PM
  3. Linear Guides with Teflon Bearings
    By cely in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2004, 11:05 PM
  4. It seems my linear bearings don't fit...
    By mikeschn in forum DIY CNC Router Table Machines
    Last Post: 01-28-2004, 10:45 PM
  5. router bearings
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 06-14-2003, 05:32 AM
