588,297 active members*
5,055 visitors online*
Results 1 to 8 of 8
    May 2007
    54
    quote mill refurbish
    I send you my X2 minimill base and saddle, You regrind the x and y dovetails.
    Need price. Would like new y axis gib strip made out of brass. How much?
    May 2007
    54
    anyone?
    May 2007
    54
    nobody??????????
    Jan 2008
    449
    You probably should post your location. Isn't scraping what you need? There is a guy on that other form that doesn't even allow CNC Zone to be mentioned who does nice work refinishing Bridgeport's. You should probably post some pics, most people I believe are assuming this is a difficult job.
    May 2007
    54
    Quote Originally Posted by Dualkit View Post
    thanks for the reply
    Im in detroit
    I would love to have it scraped, But i know i cant afford it
    heres exactly what i want done
    1. bolt base upside down, grind flat bottom
    2. flip base , regrind dovetails
    3. saddle - regrind dovetails - ensure axis are 90 deg
    at this point i would be happy to just have the y axis done, my x axis seems fine
    Nov 2004
    260
    You are showing the Ways been Milled not Ground.
    Milling is probably the most common Way to do this.
    You will need thicker Gib strips to make up for the lost Material.
    Additionaly the ways could be scraped after Milling.
    This procedure done in a Machine Shop would likely cost more then a brand new X2 Machine.
    Maybe finding a Friend with a Bridgeport type machine that is willing to do it for cheap is your best bet.
    Grinding the Ways is likely to double the cost, there are fewer option on finding someone with the required equipment.
    May 2007
    54
    if someone wants to mill the dovetails im fine with that. no grinding neccessary.
    May 2007
    54
    well... since i could not find anyone to fix my mill base, I purchased a replacement one from little machine shop.com and it works much better. Thanks
  1. Quote needed asap on production cnc lathe/mill work
    By billet works in forum Employment Opportunity
    Last Post: 09-01-2014, 12:09 AM
  2. wanted router frame to refurbish
    By Art Ransom in forum Want To Buy...Need help!
    Last Post: 09-06-2008, 03:51 PM
  3. Post here? Refurbish engraving table
    By Electech in forum DIY CNC Router Table Machines
    Last Post: 11-29-2007, 01:43 PM
  4. How to Refurbish Brass ?
    By diarmaid in forum MetalWork Discussion
    Last Post: 01-18-2007, 08:41 PM
