Is it possible to turn on a snap grid in bobcad v24 like you can in v21?
No, No grid.
Do this..
Open a new file
Create a layer called "Grid"
Draw a point at X0 Y0,
Use the translate function with copy to create a "Grid" of the desired size.
Save the file with a name that describes the Grid. Example 1inGrid.bbcd
Create several files with the Grid sizes you want. Example 1_2inGrid , 2inGrid and so on.
Use file > Merge to import the grid when needed. You can use layer control to toggle it on and off.
