Originally Posted by
billsnogo
I am just now getting the spindle turning on a bridgeport MDI retrofit. I am using a Hitachi wj200 vfd, single phase to three phase. The Bridgeport has the 2hp 2j head/motor, and according to the plate on it is 6.6 amps, 60 hz, 1700rpm (means four pole, correct?). From what I can find on the internet, if I run 120hz, it should spin the MOTOR at 1700rpm (full rpm of motor), but when I run 55hz, I get just under 4200rpm at the spindle(max rpm of the variable speed head). So, why can I spin the spindle to the rated max at such a low hz? Am I doing something wrong?
thanks in advance
bill (confused yet again)
