588,567 active members*
5,022 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > is 175 extra oz worth $10 per stepper
    Apr 2005
    81
    Looking at buying some steppers, (first run at electronics). For $30 extra there is the option of upgrading the steppers to 305 oz from around 150oz. Good deal, not a good deal, is it worth it. Let me know opinions. Looking forward to responses. Thanks
    Jan 2006
    481
    May 2005
    1810
    As far as I am concerned, the more power, the better. Without a doubt. If your machine is the size of a postage stamp, it might be overkill but if it's a reasonable size, you will likely be very happy with more powerful motors. Iit's likley you will find the limitations of any motor you put on, so when you find the limits of the 305s, you will likely be glad you didn't choose the 150s.
    This is all speculation, of course.
    That's my story.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    I'm with Scott. Spend the $30. Although letting us know what you'll be doing with them may give you a better answer.
    Jun 2003
    3312
    Motor size is dependent on machine type, size, rotary to linear conversion method. There are downsides to larger motors, they have more mass and have larger rotor inertias which typically translates in to slower accelerations and deceleration rates. Bottom line, it's all a system. Machines, motor, drives, screws, power supply all contribute to performance.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  1. Little extra help for tailstock
    By bdyenter in forum Daewoo/Doosan
    Last Post: 10-18-2007, 04:24 AM
  2. G203 with the extra money?
    By bryanrabb in forum Gecko Drives
    Last Post: 09-23-2007, 09:17 PM
  3. Just need Extra Income
    By SPYLAGZ in forum Employment Opportunity
    Last Post: 08-09-2007, 08:44 AM
  4. Extra capacity
    By cdlenterprises in forum Employment Opportunity
    Last Post: 02-26-2007, 08:58 PM
  5. Need help extra lines in dxf
    By carlnpa in forum Mach Software (ArtSoft software)
    Last Post: 03-19-2005, 10:48 PM
