I am having a problem with control power not coming on a Monarch Metalist 1A. All fuses check out good. It has Fanuc Series 15-T controls. I have verified power going to the input unit and it is not alarming. The operator says the machine was running then just stopped giving him a watchdog alarm (unfortunately he doesn't recall which one it was). He cycled power to the machine and we have not been able to get the operator panel up since. I have verified power to the monitor, I have verified that the on and off buttons work and every fuse in the panel is good. The "Operators Panel Connection Unit" is a Fanuc A16-1212-030 1/07A. It has a Fanuc A20B-1003-063 power supply board attached to it. I have verified 24 vdc going into the Fanuc A20B-1003-063 POWER SUPPLY BOARD, The two test points test out OK, 5 vdc is there as is 24 vdc. I also checked the A16-1212-030 1/07A board and it has the correct voltages as well. The on and off buttons at the control panel turn the Fanuc series 15-T controls on and off but the monitor or control lights never come on. I have verified power going to the input unit and it is not alarming. This has to be something simple but I seem to be missing it here. Wierd, Any ideas?
