Does anyone in the group have experience with swapping out the standard controller in a newer X2 mini-mill for a KBLC-19PM(MOD)?
I'm using documentation from Sonny Harrisson's site which can be found here: http://www.harrisson.biz/controller/power.htm I'm using the same controllers (tried two so far).
The controller outputs 105VDC no matter where the variable speed control is positioned (5k pot). I've checked wiring per Sonny's documentation and found no issues. The 5k pot is running from 0 to 4.2k ohms and is correctly connected.
Any help would be greatly appreciated.
After checking the terminal board conections (I removed the board so I could use a remote 5k pot) I found the it's outputting to A+ & A- instead of F+ & F-. Now I just need to get RI & CL correctly adjusted.
Dan Kolean
