Walter - mail en route, and thanks.
Just to give you a laugh, and some idea of my working methods, I attached here the first shots of my spin casting rig.
I thought I'd best test it with water before I painted the walls with an epoxy/sand stripe. All seems OK, and tomorrow morning will be the first epoxy tests.
I've been thinking of how I'll get the mix into the test tube.
The simplest seems to be to use a central tube down the axis, pour the dry pre-mix around it, followed by the resin mix down the center, then withdraw the center tube.
Fortunately, my various bits of tube will give me a 20% epoxy for the first test, and I shall be interested to see if any excess migrates to the central axis.
How have you been cutting any samples ?
I'm assuming something like a disk grinder, possibly with a diamond cutting disk.
Regards
John
Edit - the photos are left to right 2800rpm, ~2000rpm, and 900rpm with water as a test fluid.
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
