588,195 active members*
4,643 visitors online*
    Sep 2011
    EX10 Thermal Trip - Fanuc 11M
    Subject says the general problem. When the machine finishes posting I immediately get EX10 Thermal Trip, and I can't clear the error.
    I also get Hard Overtravel alerts for X+, X-, Y+, Y-, Z+, Z-. Obviously I can't have overtraveled all at the same time, particularly since the machine won't do anything in this state.
    Disclosure, I did have a problem with one of the overtravel sensors on the Y axis and I had just repaired a wire that had become lose in the sensor. Now that that is fixed, I'm getting this
    Feb 2009
    6028
    Circuit breaker is tripped. The rest of your problems indicate it's for a 24VDC line that feeds your OT switches.
    Sep 2011
    Thanks for the date, now I know I have something to look for. I'll see if I can find a breaker in the controller box. Is there some place where the breakers normally exist within the controller?
    Not to disparage the previous owner but the inside of the controller box is quite possibly the most alarming wiring mess I have ever seen in my life.... kudos that it worked but it makes me cringe moving thing to look for things
    24220
    Depends what I/O boards/system you have, but look for a fuse on any I/O boards (small green fuse).
    Al.
    Albert E.
    Sep 2011
    Found it! Wasn't familiar with this style of fuse, completely missed it last night. So now I know what a Daito fuse is
    Thanks all.
    Now to wait for it show up....
  1. fanuc alarm 1000 mcb trip
    By dhiruj in forum Fanuc
    Last Post: 09-12-2012, 10:24 PM
  2. My Trip to Ann Arbor for a 622
    By Mihelich in forum Smithy
    Last Post: 12-19-2009, 01:10 AM
  3. Fanuc OM Thermal Tripped error
    By Singlehick in forum Fanuc
    Last Post: 12-07-2008, 11:40 PM
  4. Getting my THC Min and Max to trip
    By JaiTalkin in forum Mach Plasma / Laser
    Last Post: 06-27-2008, 01:34 AM
  5. VFD fault trip
    By colin1544 in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2006, 10:48 PM
