588,370 active members*
8,681 visitors online*
Results 1 to 8 of 8
    Nov 2004
    44
    Skateboard ABEC-7 bearings
    I found some ABEC-7 (best accuracy) bearings that are originally for skateboards. They are about $1/each. See the web link below. I plan to use these bearings to build my own bearings & sliding rails. It has a 3.25 KGF dynamic load. My question is what is the load ratings in LBS (US pounds)? Can these bearings handle a 5' x 5' metal mill used to cut steel and aluminum? How do they compare with bearings normally used for metal CNC mills?
    http://www.vxb.com/page/bearings/PRO...57e70856323141
    Nov 2004
    44
    <please delete this message>
    Jun 2004
    463
    One kgf is equal to 2.2 pounds, so 3.25kgf is a little over 7 lbs. I would say that something is wrong with those specs. Using those specs, a skateboard with 4 wheels and 2 bearings per wheel would be rated for less than 60 lbs, not enough to support a large child even standing still.
    746
    That is a good price for those sealed bearings. Regardless of those numbers, I would go ahead and use them. I wonder if they meant those as an axial load. I bet if you look up a standard 608 bearing that you could get an actual rating. Besides most of your loads will be of a radial nature anyway.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Quote Originally Posted by coolman
    THK type bearings use on metal mills are rated at several thousand lbs
    May 2005
    150
    coolman,
    try these bearing same price and can take a lot more pressure.
    1080 lbs static 2148 lbs dynamic
    it has 17 mm shaft size.
    http://www.vxb.com/page/bearings/PRO...8e55c4d91caa4c
    Feb 2004
    427
    skate bearings abec 7 reply
    I am using those abec-7's on my plasma table. I have used 4 bearings to support the downward weight of my gantry, which at the moment weighs 45kg, or 100lbs. From memory these bearings can handle about 90kg each i think. Hey, I was sitting on my gantry the other day because I was so excited about actually making the gantry and how good it slides along. I weigh 100kg the gantry weighs 45, so say 150kg which is probably around 330lbs and I tell you what, unbeleviable! I could easily push myself along while I was sitting on the gantry. COOL!
    Apples
    Oct 2005
    186
    I ordered 100 of those bearings from vbx.com for only $34 this week.
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. ABEC Skate Bearings
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-26-2005, 02:07 PM
  3. Are VXB.com bearings good?
    By Evilness in forum DIY CNC Router Table Machines
    Last Post: 07-16-2004, 05:39 AM
  4. The truth about skateboard ball bearings
    By Swede in forum DIY CNC Router Table Machines
    Last Post: 04-16-2004, 11:21 PM
  5. router bearings
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 06-14-2003, 05:32 AM
