588,014 active members*
6,643 visitors online*
    Jun 2005
    93
    Can't get EMC running
    I've installed per instructions on the EMC site.
    Screen to select configuration comes up. I select one and a splash screen comes up. Then .... nothing. What am I doing wrong? I'm computer savy, just not Linux savy.
    Jul 2006
    1062
    Did you choose axis as the display? When I first installed I edited the conf file to have axis as the interface hth (I then gave up and bought Mach )
    Keith
    Mar 2004
    222
    I'm new to Linux too, and I just installed EMC2.
    I don't know what distribution you're using but it
    helps to run EMC via command prompt. The prompt
    tells you what could be wrong.
    mhel
    "This is intentionally left blank."
