We are trying to use FXS and FXST commands to develp a probing routing on a Niles Simmons 4 axis lathe. We are currently successfully using FXS command on a SEMA Endworking mill in exactly this same way and it works great as an alternative to fitting the machine with a Renishaw or other probing system.
We can invoke the FXS command on the lathe and everything looks hunky dory. The distance to go registers look good and we show no syntax or machine inhibit messages, so the block is being read fine. The spindle is set to positioning mode as mentioned in the documentation. After the block is read the Z axis simply sits there. Theoreticaly it should travel in the direction of the command until a current limit is reached on the servo drive. Then we would simple write out the positon registers an do a fixture offset, or equivelant.
Anybody have a clue on what could be causing a motion inhibit?? All machine interlocks are in place and proper bits are made.
Regards,
Steve
