587,420 active members*
3,263 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > What is largest mem expansion for -4
    Oct 2006
    79
    Hey,
    I'm thinking about a memory upgrade but it seems I need a -5 to get 4 megs or more. Could someone tell me how much a -4 can be upgraded?
    Thank you, Shepard
    Jan 2015
    417
    Re: What is largest mem expansion for -4
    -4 i believe was the version that started using Mega memory so it should beable to goto 16meg. or go to Calmotion and get the USB upgrade and you can run programs off the 32G memory stick through the DNC option. you just cant post programs using subroutines so post not using subroutines and your good to go
    Jan 2015
    417
    And the Calmotion box is the most likely much cheaper then buying dedicated memory
    Oct 2006
    79
    I have a dedicated Panasonic toughbook that I got off ebay for $65 that I DNC from with no problems and even runs my CAM software, I was just thinking about an upgrade to -5 and thinking about the benefits vs costs. I assumed my -4 was limited to under a meg. Thank you for the information.
  1. Gingery lathe largest
    By kakuma in forum Mini Lathe
    Last Post: 02-12-2014, 05:19 PM
  2. Largest parallels that can be used in a vise ?
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 03-31-2011, 08:40 PM
  3. Largest Mdf part of machine?
    By settle in forum Uncategorised WoodWorking Machines
    Last Post: 07-01-2008, 10:49 PM
  4. Largest chuck for a 7x12???
    By imhotep in forum Mini Lathe
    Last Post: 03-03-2008, 08:37 PM
