588,025 active members*
4,711 visitors online*
    Dec 2007
    236
    Tos FN20 down
    It has been awhile since I have posted or been active on this form. The issue at hand is that the 16 year old 150MHZ computer on my conversion has crashed. The computer that ran the mill was an AOpen AP5T mother board that used an Intel PP/MT150MHZ processor. The simplest solution would be to find another computer main board and swap it out. Can't find one on ebay. This build used a printer port and break out board to control the servos. Like I said it has been awhile since I have read on this form. Any suggestions of what I should be looking for to get my mill up and running again. I really don't want to change drives and servo's. A few links to get me in the right direction and an opinion or two is all that I am asking. Thanks for your consideration.
    TonyK.
    Ark1
    Apr 2004
    5755
    Re: Tos FN20 down
    I don't think there's much future in that computer, even if you could find a new motherboard and managed to install it. While it's hard to find a new computer with a parallel port, it's not impossible. The Atom, for instance, is a small form-factor computer that still has them built in: https://www.alibaba.com/product-deta...802311738.html
    You can also look for another old computer, which are often available quite cheaply, or use a new computer and a USB adapter like the UC100 to substitute for the parallel (printer) port.
    Andrew Werby
    Website
    Dec 2007
    236
    Re: Tos FN20 down
    Quote Originally Posted by Ark1 View Post
    TonyK.
    Ark1
    Thanks for taking the time to respond to this email. I think you are correct as I can find 200 used computers on ebay with printer ports and XP. That will be the most simple way to get my Mill up and running again. I will have to figure out how to get Mach3 on the new computer or if I need to purchase a new licence. If I can get the new computer I can work with the monitor and key board and possibly down load from Mach. It has been a while since I did this conversion and I know that things have progressed, but I really don't want to start over with new servos, power supplies and tech to get to the same place again.
    Thanks so much. TonyK. ( Ark1)
  1. TOS FN20 Upgrade to CNC
    By Ark1 in forum Vertical Mill, Lathe Project Log
    Last Post: 04-09-2023, 02:57 AM
  2. need help with tos milling machine
    By derkiow in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2021, 03:33 PM
  3. tos fng 63 cnc
    By teokar in forum European Club House
    Last Post: 02-03-2021, 07:27 PM
  4. TOS. FN20 information help
    By Howburn in forum Vertical Mill, Lathe Project Log
    Last Post: 09-28-2019, 09:04 PM
  5. Repair of TOS SKQ 12
    By dinofoto in forum SERVICE FOR CNC-MACHINES
    Last Post: 08-04-2009, 08:31 AM
