588,606 active members*
7,836 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > What software is necessary for RS232 Communication?
Results 1 to 7 of 7
    Jun 2006
    29
    I just posted a question about wearing out a usb port and realize that a rs232 cable is in my future. What Software needs to be running on a PC to communicate directly to a Haas? Can you drip feed from a PC or is this for whole file transfers? The reason I ask is I am limited to 1mb memory on my mill. Thanks.
    Sep 2007
    56
    dnc
    I bought a program on ebay, and it has worked out real good.
    Controllink systems. Program called machine link. 812-637-6800 is thier phone.
    You can drip feed on machines with one meg <which mine has also>
    First program I ran had several hundred thousand lines of code.
    Only problem i had, was following the direction in haas manual for dnc. they said use 19200 baud. Gave some crazy signals to machine. Called controllink,
    and they had me drop it back to 9600...been running since.
    Good luck
    Swain
    Mar 2005
    1498
    080406-1554 EST USA
    61SedanMan:
    Our I232 Isolator system would be useful to you. This provides electrical isolation at both the computer and CNC, and 115.2 kbaud up to 4000 ft. Very useful to avoid noise problems and provide maximum transfer rate of the CNC.
    In a pinch you can use HyperTerminal that comes with Windows. If you use Xmodem at 115.2 kbaud Hyperterminal has very poor thruput efficiency. Its thruput is very good in XON/XOFF. Not a convenient program with which to work.
    A rather good communication program is Cimco Edit 5, very reliable, and moderately simple to use. It does not have Xmodem capability. High baud rate thruput is very good. We use it for testing our I232 modules.
    Cimco DNC Max has Xmodem and it is quite efficient sending to HAAS. Runs at about 90% of theoretical maximum thruput for 115.2 kbaud. Receive from HAAS is somewhat slower, nothing like the slowness of HyperTerminal. Thruput is very good in XON/XOFF mode.
    www.cimcosoftware.com for Cimco
    and
    www.beta-a2.com for my web site.
    080406-2206
    awain:
    I expect your machine will stutter in areas with many small strokes at 9600 baud doing drip feed. That is 12 times slower than 115.2 kbaud.
    One CNC makes a program that is freeware file transfer and editing. I forget the name of it but I use it every day and "free" is pretty low price. I think they have a version that costs money if you use it for multile machines but for one machine it's free. Set up was about 10 minutes.
    www.wilkins-knives.com
    Aug 2007
    96
    I do not think One CNC has that download available anymore.
    Oct 2005
    1237
    Go here. NCCNet-Lite is a single machine non-DNC Freeware com system for RS232 links. It works pretty good.
    http://www.cadem.com/
    If you want to kill two birds with one stone, Dolphin CAD/CAM has a comm program as part of the package, and they offer very fair Hobbiest pricing. For the cost of a really neat CAD/CAM program, you also get the comm. Can't beat it.
    Apr 2010
    27
    Re: What software is necessary for RS232 Communication?
    Does NCCNet-Lite work with HEIDENHAIN CNC?
    I have several machines equipped with FANUC CNC but I have one with HEIDENHAIN CNC.
    I frequently need to transfer part programs and other data (tool offset etc.,) from PC to CNC and the other way round.
    With FANUC CNC I use “communication software for FANUC CNC” application that I downloaded from this site:
    Communication Software for FANUC CNC Download
    It works well with all FANUC CNC: RS232C connection (for old CNC) and Ethernet connection (for the new ones) but I cannot get it work with HEIDENHAIN CNC.
    Thank you for your help
  1. RS232 communication
    By jp41558 in forum HURCO
    Last Post: 08-31-2017, 11:42 AM
  2. Boss8 RS232 communication
    By precourt in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2009, 04:31 PM
  3. Fanuc 3M and RS232 communication
    By teamjnz in forum Fanuc
    Last Post: 04-01-2009, 10:11 AM
  4. USB to RS232 NO Communication?
    By frz400 in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 11:16 PM
  5. RS232 communication software
    By gar in forum Haas Mills
    Last Post: 08-14-2007, 02:56 AM
