Ive got the mill all wired up and I am able to send simple programs from TTerm pro to make table move around in G00 (rapid) When I send a line with a G01 and M03 (spindle on) with a feed rate, it stops at that line number and wont do anythine more. I am assuming that the interlock whch prevents a feed move without spindle on is my problem. I can "hot wire " the spindle motor and it runs fine, but in program the contactor (reversing contactor) doesnt pull in. Do some of the "NO" Aux. terminals of the contactor feed back to the XDI board to tell it spindle is on (contactor energized) ?.
As I only have maintenance manual schmatics for earlier model (up to ser# 6640) and my machine is #8946, some of the diagrams do not show the late model spindle controll panel. Mine has lo range-hi range start switch, the E-stop and a green "spindle enable" switch. I bought Operating manual Boss M-128D from machinemanuals.net, and according to that my machine should have spindle off button in place of spindle enable. The manual lists ser #s up to 9099. Maybe mine got a upgrade that slipped thru?
Can anyone tell me the right procedure to turn it on? As its been many years since I ran a machine similar to this (This machine was'nt even built yet) Its a good posibility of it being an "old operator error" problem. The "low oil level" switch has been jumped to bypass low oil defective switch.
I also can enter in moves with the MDI keypad in rapid travis speed, but not with a Mo0-G01-f-feedrate entered.
I am running machine from a well balanced three ph generator, and have the 2 "factory" legs feeding the power transformer that supplies the 110v. All of my other 3ph machines start and run fine.
Any help is much apreciated.
Paul M
West edge of NY state
