587,128 active members*
3,239 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree J425 Help and Looking for Schematics
    Dec 2009
    I have a 1997 Tree J425 with the Vickers Acramatic controls.
    Its been working well for me until today - I just got the following alarm which has stopped the machine dead in its tracks. I can't even jog the axis.
    Alarm 90-4
    Cause: Coolant motor overload protection has tripped.
    Remedy: Reset motor overload, check motor current.
    Would this be the spindle motor or the cutting fluid coolant motor?
    Also, would anybody have any electrical schematics for a similar machine they would be willing to scan and email or point me to a link? I know its probably a long shot...
    Thanks in advance,
    Mike
    Feb 2009
    6028
    J425
    Coolant pump motor overload relay has tripped. Press re-set on the relay and clear the alarm.
    Dec 2009
    Any ideas why it would overload while not being used?
    Feb 2009
    6028
    425
    If your sure you didn't turn it on briefly, then you may have lost power through the 24VDC circuit running through the overload relay for the alarm circuit, or just the contacts on the overload went bad. You can manually trip it and re-set it and see if it comes back up.
    Dec 2009
    I found the M8 code in my program which toggled the pump on.
    Good news was that there must be some kind of thermal overload protection as the alarm was cleared this morning when I started up the machine.
    I couldn't find any reset-able relay. After tracing the wires I found what looks like a home brew Triac driving the pump...it might be a 3 phase pump motor with U V W connections. Don't know about the voltage as I didn't want to poke around in the cabinet after seeing that the machine was working again.
  1. Tranformer schematics?
    By CNC Pro in forum Fanuc
    Last Post: 08-14-2012, 05:05 AM
  2. tree 2uvr-c tree mill
    By willcofab in forum Tree
    Last Post: 06-11-2009, 07:40 PM
  3. need schematics for tree millinium 3100
    By 1933ford in forum Tree
    Last Post: 08-25-2008, 04:59 PM
  4. VF Schematics?
    By gromit68 in forum Haas Mills
    Last Post: 07-06-2007, 05:56 PM
  5. Are these schematics appropriate for CNC use?
    By ipodman1991 in forum CNC Machine Related Electronics
    Last Post: 11-27-2006, 12:59 AM
