587,998 active members*
1,701 visitors online*
Results 1 to 8 of 8
    Sep 2006
    10
    grooved steel cylinders
    I was hoping someone could help me out. I need 3 items machined. Please see the dfx file attached for the specs. Material: regular tool steel I guess? Units: decimal inches
    They are to be used as bending rollers in a jig for shaping ski and snowboard edging.
    Attached Files Attached Files
    Dec 2006
    45
    rollers
    would like to help, but I can't open dxf files. Could you post in pdf? Thanks, Howard.
    Jan 2008
    449
    How wide is that .300 deep groove at the bottom of the .076 wide groove?
    Can you design that out? That feature is going to be pricey to make, everything else is easy.
    15362
    How wide is the smallest slot I don't see a number/dimensions for that slot
    Mactec54
    Sep 2006
    10
    Sorry the smallest groove is .025" wide. But if that is too small it can be bumped up.
    Sep 2006
    10
    here is a pdf
    Mar 2008
    93
    what kind of tolerance?
    I don't see any major problems but do have a couple of questions. You have everything out to 4 decimal places, how close do they need to be? I am guessing the .250 hole through the middle needs to be fairly tight, what about the rest? How soon do you need these? Thanks.
    Sep 2006
    10
    RFQ Closed. Thanks
  1. best way to control 25 air cylinders?
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 01-17-2010, 12:04 PM
  2. Hypertherm consumable life - air cylinders
    By energyforce in forum Waterjet General Topics
    Last Post: 05-29-2009, 06:59 PM
  3. Need to control 40 to 60 cylinders... ugh
    By SuperBob in forum CNC Machine Related Electronics
    Last Post: 03-29-2009, 09:05 PM
  4. Triple Machined Tongue & Grooved Tee Rail
    By MBG in forum Linear and Rotary Motion
    Last Post: 03-14-2008, 09:44 PM
  5. Air cylinders, PSI & Force they have ???
    By Chris D in forum Mechanical Calculations/Engineering Design
    Last Post: 05-01-2006, 05:23 AM
