588,711 active members*
5,990 visitors online*
    Mar 2014
    5
    Exclamation New CNC with Servos - Should I convert from NCstudio to Mach 3 ???
    I just got my new cnc router. It has servos as opposed to steppers. It came with a pci control card and NC studio (which I have not been able to get to work).
    Attached are some photos.
    From what I understand (limited), NCstudio has a look ahead feature to speed up machining. Does Mach 3 do this?
    Does Mach 3 control servo motors?
    Any ideas on what I need to do to convert over to Mach 3?
    Thank you!Attachment 237718 Attachment 237720 Attachment 237722
    Mar 2014
    5
    Re: New CNC with Servos - Should I convert from NCstudio to Mach 3 ???
    I got my cnc working using Mach 3. So smooth with the servos. It was important to connect the 5V from the computer USB to the controller.
    I currently have all the wires taped together. I just bought a BOB off Ebay to help with protecting the computer etc. see attached.
    Only issue is the inverter for the spindle has a low, medium and high speed. Mach3 only handles off/on by setting a pin to 5V. My problem is that when it is off, the voltage on the pin is 0.07V and this causes the inverter to turn the spindle on. The inverter is HL3000 (2055-T). I have to temporarily install a switch for the pin out of Mach 3 to prevent the inverter from turning the spindle on.
    It is confusing without a manual. As for the spindle speed, the inverter says 250 but the spindle seems to be at 10,000 rpm. I have no idea what that thing is doing.
  1. Conversion NCStudio to Mach 3
    By bill south in forum Chinese Machines
    Last Post: 06-08-2020, 08:18 AM
  2. convert to mach 3
    By luvpakn in forum Mach Plasma / Laser
    Last Post: 12-28-2013, 05:40 AM
  3. SX3 convert ..Tapping with mach 3 possible
    By Vatorman in forum Benchtop Machines
    Last Post: 02-08-2011, 05:47 PM
  4. What all parts to convert cnc jr to servos?
    By blazer928 in forum Servo Motors / Drives
    Last Post: 11-15-2006, 08:01 PM
  5. Mach&servos
    By lgalla in forum Servo Motors / Drives
    Last Post: 10-17-2006, 03:23 AM
