587,611 active members*
3,701 visitors online*
    Sep 2021
    Bridgeport with CNC conversion
    I've had this for a few years now and looking to downsize with a country wide move. When I bought it had just been through a check by a local Bridgeport specialist that I trust and had used for business work as well.
    I have enjoyed this machine a lot and wouldn't even be considering selling it it I wasn't moving.
    I know its messy in the photos but that's because I use it all the time and I was doing some ball endmill contouring (hence the quill way out).
    If you put in the effort to a solid setup and good G-Code I have no trouble holding .001"
    The Belts could use some covers fabricated and maybe some motor mounting improvements or some better belt tensioning.
    Includes:
    CNC Control Box w/PC and Monitor
    UCCNC License
    Mist Coolant - CNC Controlled
    Air Blast - manually controlled, can be added to CNC easily
    HIWIN Ball Screw Upgrade XY
    Royal Quick Change Tool Holder
    6 assorted tool holders for Royal
    Drill Chuck
    Cheap Vice
    VFD for Powering 1ph to 3ph
    Teknic Servo Motors
    Looking for $6500 located Buffalo/Rochester NY region
    Sep 2021
    Re: Bridgeport with CNC conversion
    Price Update $5500
  1. Bridgeport CNC Conversion, Yes another one, for me too!
    By Cartierusm in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2019, 09:25 AM
  2. Bridgeport CNC Conversion
    By nikel in forum Bridgeport / Hardinge Mills
    Last Post: 11-01-2012, 03:52 AM
  3. Bridgeport CNC conversion
    By chris123 in forum Bridgeport / Hardinge Mills
    Last Post: 01-24-2012, 01:38 AM
  4. bridgeport clone cnc conversion
    By diycnc in forum Knee Vertical Mills
    Last Post: 09-04-2009, 11:20 AM
  5. Bridgeport cnc conversion?
    By Bryscnc in forum Bridgeport / Hardinge Mills
    Last Post: 03-11-2005, 02:07 AM
