588,616 active members*
5,973 visitors online*
    Mar 2004
    169
    Wink easy wiring question
    I have searched the net to no avail for the wiring for a superior electric slo syn stepper mo-63. This should be easy. The connector has the wires in the following order ,red,black,brown,green,white,blue.A six wire motor.Im using gecko g-201's.Should I just use the first two and last two.(black,red,white,brown) and ignore the two center wires? Or should I be worried that they are o.e.m. orders with odd wiring. Also would I just connect the two center wires together? Thanks all for any help.
    P.S. I suggested along time ago in the forums that someone should start a new category for a motor wiring data base. I know it would get alot of use.
    Mar 2004
    169
    Talking OOPS! Forgot.
    Oh! I almost forgot. i would like to wire them bi polar parallel for max torque.
    Jun 2005
    208
    Use a multimeter to measure the resistance between the various wires. Since you have a six-wire motor, three of the wires will go to one coil and three of the wires will go to the other coil. For instance, on an M092-FD09 motor that I have, one coil has Red, Black and White/Red wires. The other coil has Green, White, White/Green wires. The Red and White/Red wires on one coil and the Green and White/Green wires on the other coil are used with Bipolar Series wiring. Either the Red and Black or the Black and White/Red wires on one coil and either the Green and White or the White and White/Green wires on the other coil are used when the motor is wired half-coil. Because the motor only has six leads, it cannot be wired Bipolar Parallel. Bipolar Parallel wiring requires eight lead motors.
    If I may be a little blunt, why are you using that old motor? Motors and drivers are the very heart of a CNC machine. Instead of trying to make an old motor work, why not save up $50 - $100 and buy a new powerful square type motor that has a data sheet? Personally, I always use Oriental Motor stepper motors and Gecko stepper drivers in all of my designs. I often tell newbies that they can work one week-end at the local McDonalds and earn enough money to buy a quality stepper driver and a quality stepper motor, or they can spend weeks messing around with old stuff in an effort to make it work. I consider any round motor to be old stuff and not worth much effort. (I keep a drawer full of old Slo-Syn motors and old PK299 motors to show visitors. They're interesting to look at but nearly worthless when serious work needs to be done.)
    Mar 2004
    169
    Thanks for the reply, I had it lying around and its double shaft, Just what I need for my z axis.Tired of moving it by twisting the coupling with my fingers.
    Dec 2007
    33
    1 on 2 on
    Quote Originally Posted by Richards View Post
    I can assume this is what the spec sheet refers to as 1 or 2 on?
  1. Over the top easy question from total noob.
    By GregoryA in forum MetalWork Discussion
    Last Post: 10-01-2005, 03:41 PM
  2. Easy question, Hard solution
    By CBNDude in forum Mechanical Calculations/Engineering Design
    Last Post: 06-10-2005, 07:04 PM
  3. Stepperworld SP-3/HT wiring question(easy one)
    By FlyElectric in forum Stepper Motors / Drives
    Last Post: 04-17-2005, 12:07 PM
  4. easy to answer question
    By senor J. in forum Mach Software (ArtSoft software)
    Last Post: 01-28-2005, 01:34 AM
