588,068 active members*
4,727 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Apr 2006
    3498
    Making a Steel Cutting Router
    I have not seen in this Forum a Router that cut Steel components.. I am watching Milling Machines with Movable bed .. I think the Milling Machine are more rigid and sturdier than a router...
    But My current job requirement is a Carbon Steel Cutting Router.. For Hole drilling and Machining of HeatExchangers Tubesheets and its Baffles... Following will be the specifications of the Route:
    1- Cutting Area 5feet x 5feet x 1feet (X,Y, Z)
    2- Accuracy and repeatability 0.01mm
    3- Hiwin Rails will be used as linear slides
    4- Using of Precision Ball screws
    5- Will search for a good 3Hp spindle
    6- The bed will be 1" thick Cast Iron with T-slots
    7-The remaining structure including the Gantry, Z-axis and Y-axis bed will be Heavy Structural steel
    8- I will use 1200 Oz-in Stepper Motors (02 on X-axis , One each on Y-axis and Z-axis)
    Is it possible to machine Carbon steel with a Router?.. I will use DOP 2mm Per Pass and Looking a Feed of 20 IPM...
    Please share your ideas with me... You can give me Links of Router cutting Carbon steel...
    Regards
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Mar 2006
    2712
    Khalid, what you are proposing sounds like a light duty bridge mill to me.
    Dick Z
    DZASTR
    May 2007
    767
    Hi Khalid
    This will be a monster of a router and is heading to be a verical mill or bridge mill as suggested by Dick Z.
    1. The weight of the cast iron table will exceed 400kg (900 lbs) and possibly treble this ias you intend to have 'T' slots let into the top surface of the bed. The bed will require a careful design of strengthening webs on its under side to give adequate stability - look to the design of a cast iron surface plate of that size to give you the sort of cross bracing and webs that are required. Initial machining would be a difficult to do on the actual machine due to the tough nature of the outer skin on a sand cast iron item.
    2. This is going to be a tough order to maintain over 60 inches. Look at the ballscrew specs and be prepared for the price as these will have to be large diameter. The use of servo motors and linear glass scales would be a better approach and you could then use a less highly specified ball screw as the absolute accuracy is provided by the glass scale.
    3. Yes but to get the necessary ridgidity over the 60 inch span of the bridge will entail a very robust and hence heavy assembly. You should be thinking box ways not simple slide rails although the total weight of the bridge will help to dampen any tendency for the bridge to tilt under the infulence of cutting forces.
    4. Same observations as under 2 for accuracy use glass scales as the feed back element in a servo system as this will be cheaper and much better than using precision ball screws.
    5. I sense that this is not the right approach. Identify the cutter you will be using and from there obtain the speed and power required. Mild steel in thin section is nasty stuff to machine if you are going to rely on 'T' slots and clamps to hold the work down. Much better to thing along the lines of double sided tape and a sacrificial ply or mdf backing plate that is screwed at frequent intervals to the bed. A magnetic chuck would be the ideal but one hell of a device if you must take a 60 inch square sheet at one go. Why not chop the sheet up first and make the mill that bit smaller.
    6. I have responded in 1 as this is linked to the size weight issue. The use of 'T' slots I have questioned in my response to 5 as mild steel in thin section and under high feed rates can pickup on the work. You will need to think of both swarf removal and adequate cooling and lubrication of the cutting tool. As mentioned under 5 above.
    7. Do the sums on a gantry that is to deflect less than the 0.01mm you have set which has also to accomodate the other inaccuracies in your machine that in the z direction. It may be that you don't require to control 'Z' to the same accuracy as 'X'&'Y'
    8. Do some preliminary design work. The motors need to drive your gantry and the mass to be moved and the speed required will indicate the sizing of the motor. You have two additional considerations - How do you drive the gantry (one sided drive has issues with judder due to the axis twisting and most special builds use separate but linked ballscrew drives on each side of the gantry)? - Is the stepper resolution and linearity suitable for the application? Steppers have their own rotation inaccuraqcies in athe way a single revolution is divided as all the steps have a possitional tolerance. The use of linear glass scales with the scale used as the feed back element with servo motors not steppers is the way most designers go.
    Kind regards and hope the budget is big enough
    Pat
    Quote Originally Posted by Khalid View Post
    using a router isn't a great choice and it won't have the accuracies that your looking for but can be done within a thou or two , your planned feed rate will burn up your tool quickly , use AlTin variable flutes and if your router is 25000 rpm then run it at about 100-120ipm (assumiming your using a 1/2" end mill ) with light depth and engagement with high speed toolpathing .
    best thing to do would be to find yourself a proper spindle to match the machine that you plan to build .
    for the gantry and base are you planning on welding and or bolting together the structural steel ? if so then you will probably need to pour a thick concrete slab so that the machine will not shift along with the floor and affect the tolerances that you want to control , if its a solid cast iron base then it shouldn't be as much of an issue
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Apr 2006
    3498
    Hi Pat, Thank You for your valuable feedback and time... Following is my Point to Point Reply...
    Quote Originally Posted by wildwestpat View Post
    Hi Khalid
    Ans: I totally agreed with you and no doubt I have in mind to make a Truss-support structure for holding the heavy top bed plate..I was thinking that i will level the Top plate with the Router itself, but Now I will see some more ways to reduce the misalignments and inacuracies in the bedplate so that minimal DOC require for the router to surface the Bed... I think of using Cast Iron bed for vibration dampning..can i use ordinary thick Steel plate as bed... As far as T-slots are concerned, We can have some alternate ways to hold the Work Piece...
    Ans: Tomorrow i will raise PRICE ENQUIRY for 6ft 1" dia ball screw, and will see the actual price... However as per your advice I will also study on the servo and linear glass scales as i am newer to servo things... I will make the drawings of the machine and will share with all of you... I am Incharge of big Machine shop( Later i will disclose the capabilities of the machines i have)...
    Ans: Agreed with You on this... The first day i have in mind to get the accuracy the machine should be heavy weight, rigid and carfully designed... The most important for me is the design of Z-axis... It should be very rigid and accurate... Again In the Drawings I will show you the sizes and thickness of H-beams, C-channels, Angle Irons that will make the Gantry...I have doubt on the vibration dampening capabilities of structure steel.. So i have to make some concrete pouring arrangments or other ways as per yours suggestions...
    Ans: I will Look into it... Thanks for guiding me...Currently I have 1200 Oz-in 4amp/phase 80V Stepper Motors....The servos will be in my secondery List, If i failed in stepper i will definitly look for servo system...
    Ans: Yes You are right, I gave the 20IPM and DOC values as the Minimum the machine should able to do... I know the Feed, DOC depends on many parameters i.e. Spindle Speed, No of Flutes, Material of cutter, Size/Dia of cutter, Cutting Fluid etc...
    I use Double sided tape on my wood router... I never saw double sided tape and MDF backing plate on any metal cutting machines.. Do they have power to hold the workpiece combating heavy cutting forces and cutting fluids?...
    Hmmm.. some time we have Tube sheets upto 5feet in diameter.. On which we have to machining and later drilling operations.. Currently the drilling operation is manually and very hectec... We have three radial drill machines and currently we are doing drilling of baffles plates each 20mm thick (Material is Low Alloy Steel A182 F22 or equivalent) Almost Eight plates are tack-weld and then they go through drilling operations ( 19.05mm final hole dia)... So we change the drills sizes more than 5-times to get the final size...
    This is the reason I want to make the working area 5ft x 5ft.. I know the smaller the working area the rigid the machine and less complex design...
    Ans: You are 100% right... But Once the workpiece hold with the clamp in T-slots...The machining operation started , then all the T-slots will strted filling with chips and may be the chip removal will be difficult.. I need your advice and suggestion for improving the clamping system...
    Ans: The precision in all axes i wanted from the machine should be not greater than 0.01mm .. I am thinking of no-flex, 0-alignment Gantry and Z-axis...
    Ans: I am currently brain-storming and need suggestions from you before putting the design in computer... I am keeping in mind the heavy cutting forces, acceleration deceleration, inertia of the system, precision, rigidity, heavy weight etc...
    I will drive the X-axis with two motors along the two sides not with one motor in the center... This will reduce the racking issues.... I will again look into the servo system and glass scales ...
    Kind regards and hope the budget is big enough ( No..I have limited budget.. But the Plus point is that I have all the material (Structure steel, machines, manpower) except servos, linear slides and ball screws available with me)Pat
    Sep 2005
    1195
    Gantry mill
    You may think of gantry mill but less steel such as in thickness, in width of structure, etc.
    Apr 2006
    3498
    Quote Originally Posted by dertsap View Post
    Hi Curt,
    The Spindle RPM will be within 0~ 10000 RPM with VFD control...For rigidity I am thinking of Welding+Bolting.. Yes , The Foundation will be RCC concrete to hold the Machine weight and solid anchor... I don't have Foundary and if i go to the Cast Iron Option, this will add up a lot in the budgeted amount..
    Sep 2006
    122
    Check out
    http://www.mechmate.com
    It is a full size steel construction table that can do drilling operations.
    Some are even using the machine to route aluminium. Just making small passes.
    But for drilling you can set the Z axis feed and the system is desinged to give if you try to feed in to fast.
    MetalHead - http://www.mechmate.com
    Apr 2006
    3498
    Quote Originally Posted by Mike Ray View Post
    Check out
    Hi Mike,
    No way...Mechmate can't handle the high cutting forces when working with Steel... Do you have any reference of Mechmate cutting/Drilling in carbon steel plates???
    Regards
    Mar 2006
    2712
    Khalid, You may want to investigate the Newall "Spherosyn" for a feedback system. I used this to replace glass scales where we had a vibration problem on large machinery.
    Those were 12 ft. long scales on a 24 ft. dia. vertical boring mill. 1 on the right hand and 1 on the left hand ram.
    Also, a 1" ballscrew might be a bit light for the length.
    Dick Z
    DZASTR
    Jun 2004
    6618
    Yeah. My little steel frame router will route aluminum okay. No way it would do steel though. It is simply material with much different properties and requires much more rigidity to work. You can actually mill aluminum to some extent with standard woodworking tools. You won't get anywhere trying that on any steel.
    That said, if it is only drilling ops, then there is a possibility for a router. Any other type machining though and you have to have something built at least as sturdy as a mill. Could be a spindle type that some call a router, but needs beefy bearings. Plunging even mildly into steel puts all the load on your bearings. That is as long as the gantry doesn't give any.
    I am interested to see what comes out of this and if it will still be called a router when completed.
    Lee
    May 2007
    767
    Hi Khalid
    The ball screws need to be longer than the travel to alow for the gantry overhang. There are tables and graphs that show the diameter of the ball screw required for a given speed of rotation and the bearing supports. Work out how big a diameter you need as well as looking at the possitional accuracy over the travel you intend. Take into account the point at which you nominate as zero for measurement as this will give the best results rather than take the axis end stop as datum zero. The accuracy is tru possition over the travel not the accuracy over a much shorter distance.
    What are you machining? Is this machine to drill holes with a tqwist drill or are you going to pocket mill with an end mill? The forces needed for drilling by plunge cutting with a twist drill give large upwards forces which will have to be factored into the design.
    Not sure I understand the tack welds. Are these weld holding several sheets of thin material together? If so the metal is sure to pick up on the drill and probably on a mill bit with anything other than a reverse helix (down cutting) - climb milling is almost certain to pick up on the edge of multiple sheets unless very near to the clamp point.
    Yes double sided Scotch tape is ok just clean all surfaces and use safety clamps as well. In some cases glue is useful but do ensure safety clamps as well.
    Can you arrange for the part or the waste to permit clamping bolts to be inserted into a sub support / jig. Drill the holes with the jig and then use as an under sheet - just an idea but one I have used on a much smaller scale to machine very thin material.
    You might like to experiment with an expoxy cement filling for box beams as a help in damping. However you need to make a cross braced structure like a minature rail / raoad bridge - this is where the bridge mill name comes from I guess! Don't forget it can resonate in all planes.
    You might like to think about using a separate mobile clamping arm that follows the cutting head. Clamp - mill a portion of the job - stop the cutting - raise the clamp - reposition clamp and re clamp - start cutting again.
    The swarf removal is a problem and as you will probably have to use flood cooling (mist cooling might be a long term health hazard) you would have to use some form of vaccum extraction with a fluid recovery system. Cleaning out the 'T' slots would be labour intensive but not impossible - however I would avoid 'T' slots if possible and use a tapped hole metal plate as a sub base. I have suggested using the sub base as a jig to drill clamping holers OR devise a mobile clamp and do the machining in stages.
    Good luck with the design. Regrads Pat.
    May 2005
    1662
    This project would be a lot easier if a donor machine could be found. Most of these machines had really long tables but you modify around that. At least you'd have some nice castings to work with. A company I worked for retired a Burgmaster that would have made a nice donor and it may still be sitting outside waiting for the price of scrap to rise. We need a good teleportation device to get this thing to Pakistan
    It's surprising how few router designs featured here use a fixed bridge (bridgemill) design. Maybe people can't spare the extra space required.
    Watching this thread with interest.
    Anyone who says "It only goes together one way" has no imagination.
    Jun 2007
    3891
    you can mill carbon steel with a gantry, even a lighter weight one. you need to get the right tooling and cutting data. youve provided very little info on what you are cutitng though. you want to take the high speed machining approach here, using light passes are high feeds (mild steel, 1/4" 4 flute tialn bit, 12000rpm, .02" doc, full width, 120ipm, 0.4hp, 16lbs tangential force). this reduces forces on the machine meaning less flex and more accuracy. it also reduces heat in the spindle and workpiece which also means more accuracy.
    but accuracy is the main problem with your spec. 0.01mm is 0.0004". thats not really possible without both glass scales and some highly advanced thermal monitoring and compensation in the machine, screws and spindle. so mach3 is out. this is the type of accuracy $500,000 machines struggle to give. repeatability will be less of an issue, but absolute precision will be near impossible. few people will be able to align the machine and grind the table to that precision and hiwin rails do not have running paralelism that good even on their super expensive ultra precision grades. steppers are also out of the question as their stepping accuracy cant remotely match what you want.
    also, 20mm ball screws are tiny even for a woodworking gantry with 5 feet travel. most metal cutting machines with this much travel have 60mm+ screws.
    i think you need to find out what you actually require for absolute precision. 0.03mm will be a more achievable target across the travel i think. most jobs tend to require only localized precision and overall repeatability. making 2 holes precisely 19.05mm is "easy". making them precisely 1200.00mm apart is unlikely at best.
    Sep 2006
    122
    Routing steel - I agree no way for sure. You would need a good rigid Mill for that.
    But I know folks are doing aluminium routing but the max cycle is about 20 thou. So it is a slow process.
    I would think it could plunge drill steel sheets though. I'll ask to see if anyone has done any drilling in steel with there table.
    Just thought it may give ideas for a gantry.
    Might be a cool thing to take a linear rail application and attache a Bridgeport J-head or say take a Head off of an Industrial Hobbies mill and mount it to a rigid gantry.
    Then drive the Z head on the mill up and down instead of moving the whole rig like you would a router...
    Just thoughts...
    Mike
    Mike
    I disagree , it can be done and has been done by me
    it's all about how the job is approached , a router doesn't have much in the way of torque so the cutting path needs to suit the application , i started the feedrate at half (60ipm) then half way thru the vid its bumped up to 120ipm .
    there is no way that this will compare to a gantry mill but where theres a will theres a way . the cutter looked as good when i was done experimenting as it was when i pulled it out of the sleeve
    [ame="http://www.youtube.com/watch?v=s1ftb_cA4nE"]YouTube- cutting steel[/ame]
    Jun 2004
    6618
    The main reasons other than rigidity that I said no to routers was the heat and the fact that the chips would fly possibly into the motor housing. Not the case with a spindle. Heat and bearing longevity would be though. The heat issue on an enclosed spindle could be solved with coolant.
    Nice job on routing steel though. It must be leaving needles everywhere. You can't side cut every type job. Some plunge cutting is inevitable I would think and that is where we start having issues.
    What cam were you using?
    Lee
    Quote Originally Posted by LeeWay View Post
    needles and pins were everywhere , heat was not an issue what so ever though
    in regard to side and plunge cutting thats why I said in my first post that it would be best to get the proper spindle ,routers are meant for wood but as I stated where there's a will there's a way if needed . chances of getting endless hours of cutting is slim to non with a wood router , good point about the chips getting thru the top , I'm drawing up an aluminum part right now that I'm going to be cutting , I think i'll cut a chunk of furnace filter to place on the top
    as far as cam went with that steel part , i didn't use one , its a simple looping routine that only took a few lines of code to create
    Sep 2006
    122
    That's awesome !!!
    May 2007
    781
    If I understand your job requirements I think you are looking for a machine built like the BR60 or BR80 shown on page 15 of the PDF.
    http://www.milltronics.net/Resources/Images/2974.pdf
    Or even better a TT60 or TT80 a few more pages in.
Page 1 of 2 12
  1. Tips for making simple steel rule dies
    By leathersmith in forum Diemaking / Diecutting
    Last Post: 03-06-2023, 04:29 AM
  2. Making cutting oil? out of motor oil?
    By Gunther45 in forum MetalWork Discussion
    Last Post: 04-05-2010, 04:30 PM
  3. Cutting Stainless steel on a CNC Router (MultiCam)
    By routski in forum MetalWork Discussion
    Last Post: 03-27-2008, 06:00 AM
  4. Selecting a steel for making a machine hammer?
    By Mr.Nerd in forum MetalWork Discussion
    Last Post: 05-06-2007, 10:28 PM
  5. Making steel ways?
    By ZipSnipe in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2006, 04:18 AM
