586,103 active members*
3,514 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Nov 2007
    483
    Re: Yet another router table :)
    Quote Originally Posted by v0dka View Post
    I saw that too, i didn't know about it. Just need to know where to buy it here in Belgium
    I believe you just make it yourself. I'm not certain the type of glue to use. Epoxy of some sort?
  2. #22
    Jul 2018
    6341
    Hi Jack & others - I use epoxy or contact cement. Contact cement has advantages, cheaper and strong. Up to you. And yes you laminate the ply yourself. You can rough the sheet down to size then laminate then finish cut and drill. Use a hard spec aluminium. Not soft stuff. Soft tempers will crush under bolt loads. About 2mm thick is a good starting thickness... Also can laminate extra bits on where local stiffness needed. Laminated metal is common in aircraft industry look up "GLARE" Peter
    https://en.wikipedia.org/wiki/GLARE
  3. #23
    Jul 2018
    6341
    Hi V0dka - As an aside and since your happy to work in plywood and since your CAD skills are very good I suggest you consider a UHPC machine. Making mdf moulds is straightforward and then you can design and build parts that are more suitable for the job. Your machine has 100's of bolts, brackets spacers, All of these can be consolidated into 2 or 3 simple parts. There are high performance grouts available that are as good as aluminium. Where your heading is a complex, inefficient structure. It can be much simpler, plus concrete & mdf is cheap.. The two vids use epoxy granite but my current costing on UHPC concrete comes out half the price of using epoxy...Peter
    https://www.youtube.com/watch?v=GzBAJTgo3QU
    https://www.youtube.com/watch?v=2woA1BxZ7Pg
  4. #24
    Dec 2019
    17
    As I said, the first version will be made out of plywood, and then, machining myself aluminium parts. I will probably use your approach (ply + al) for this first version
  5. #25
    Dec 2019
    17
    in parallel of the machine design itself, I'm also diving into the control box design.
    I'm planning to use shielded cable either inside the control box. To wire the stepper driver to the control board, I would like to use FTP cable Cat 6 : 4 twisted pairs ( EN, DIR, PULSE and ALARM). Would the cable gauge be enough ? I think so because these have hust to drive opto coupled inputs. What do you think ?
  6. #26
    Dec 2019
    17
    My build is going on... I've almost finished the Z Axis.
    I followed the advice of @peteeng about plywood + alu sheets. I didn't any affordable 2 mm alu sheets near my home, so I chose 0.8mm steel sheets (i guled them with neopren glue) : I'm happy with the result: it seems rigid as h***.
    For the threaded holes, I' used wood inserts, inserted from the back side. So I can tightened really hard with any risks of tearing off.
    I've also add a steel plate (5mm thick and 45mm wide) on each side of the Z plate to increase the rigidity (screwed and glued with epoxy glue) : seems promising
  7. #27
    Jul 2018
    6341
    Hi VO - Looking very good... Peter
  8. #28
    Nov 2007
    483
    May I ask what motor mount you are using for your Z axis?
  9. #29
    Dec 2019
    17
    Quote Originally Posted by jckstrthmghty View Post
    Nema34 5Nm closed loop
Page 2 of 2 12
  1. Replies: 0
    Last Post: 05-18-2017, 04:28 PM
  2. DIY CNC router table help
    By moonrouter in forum Mach Software (ArtSoft software)
    Last Post: 09-23-2016, 09:02 PM
  3. 4x10 Homemade router table - CNC router parts
    By graphicideas1 in forum For Sale Only
    Last Post: 11-05-2014, 02:30 AM
  4. New DIY Router Table -- Need a little help
    By Cocytus in forum DIY CNC Router Table Machines
    Last Post: 10-09-2014, 12:11 AM
  5. with a Precix Table Router with Perske router
    By SignShop Grunt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2010, 10:08 PM
