587,798 active members*
3,273 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Electro Erosion Wire Cutting
    Sep 2007
    10
    Question Electro Erosion Wire Cutting
    I currently got a job as a machinist on a fairly old wire cutting machine and i'm also a beginer in this domain so i'm working/learning Problem is that i can't find a simple straight on .dxf to .iso converter software till i learn to write the code on my own (btw i'm designing in AutoCAD) ... can anyone help? :stickpoke
    Sep 2007
    10
    i found Kipware for wire EDM and EspritW ... anyone knows if theyre any good? kinda expensive though...
    Aug 2005
    301
    Electro Wire Erosion
    This may be controversial but BobCadCam has a product called Bobwire specifically for wire EDM work.
    ErnieD
    Sep 2007
    10
    Thanks for reply ErnieD i'll try it ... problem is that the designer makes the drawings in Acad ... but i think i will de able to tranfer them, redraw or something
  1. Edm wire erosion
    By Klox in forum Waterjet General Topics
    Last Post: 09-14-2007, 07:54 AM
  2. Electro-Craft 703
    By Bird_E in forum Servo Motors / Drives
    Last Post: 12-08-2006, 11:46 PM
  3. CNC diamond wire cutting machine
    By DennisCNC in forum Community Club House
    Last Post: 09-25-2005, 05:40 AM
  4. CNC sheet cutting comparisons: laser, router, punch, waterjet, wire edm...
    By InspirationTool in forum Waterjet General Topics
    Last Post: 06-24-2005, 07:22 PM
  5. Wire cutting big faceted shapes
    By terraswarm in forum CNC Wire Foam Cutter Machines
    Last Post: 02-10-2005, 11:53 PM
