I'm looking to replicate an aluminum box similar to the attached photo. I'll use 6061 aluminum somewhere between 1/16" & 1/8" thick (depending on press capacity) which will be milled to the flat-open-cube shape on my CNC Mill and then pressed into form. The final box will be 1" wide, 0.5" tall and 0.5" deep (so quite small...)
I don't have any experience with the next steps, but would appreciate any comments on the following "next steps":
1) Mill a cavity form that I will lay my aluminum-box work-piece (which is still in a flat cut-out shape)
2) Lay the interior-cavity shape on top of the work-piece
3) Use a desktop press to form the aluminum piece into my mold
4) I don't yet own a press. Any recommendations on a small (desktop) sized, quality press? Grizzly has one, but I don't like their low-quality I've seen in their other products. I have a decent budget and would prefer to buy something quality - but it needs to be small. (http://www.grizzly.com/products/2-Ton-Arbor-Press/H7830)
FYI: For steps 1 - 3 above, in case my explanation isn't clear, an analogy would be making a cupcake, where I mill the cupcake-tray for the form/shape, use the actual cupcake as the opposite-piece (which I've also milled) for the inside form/shape, and the wrapper is my work-piece that I am trying to press-into-shape.
Thanks!
John
