588,487 active members*
5,309 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > osp7000m rs232 setup
    Jan 2010
    Unhappy osp7000m rs232 setup
    I do not know which parameter for rs232 communication when I transfer file just one or two line comes about one minute ! help! thanks
    Mar 2009
    1982
    OSP7000 RS232
    let's start with one thread.
    So. Your problem still is not clear.
    Have You so small file only two lines?
    or:
    Your file is large, let's say 2kB, but only two lines of file are received.
    which case?
    Your cable diagram, please.
    What about transfer to other side?
    Jan 2010
    hi
    lines ;for example 'x3'
    I want to send file machine to pc or pc to machine . files are not too big ,just about 1k
    I use enterprise multi-dnc program for transfer and cable is
    9 pin 25 pin
    2-----------------------2
    3-----------------------3
    5-----------------------7
    4-1-6 short 6-8-20 short
    7-8 short 4-5 short
    I use this cable and program in fanuc control and mitsubishi control unit and there in no problem
    I do not know okuma rs232 setup
    thanks
    Mar 2009
    1982
    cable is correct for communication. For settings and adjustments it's better to add two more pairs to cable:
    DB-9: 1 =DB-9:6=DB-25:20
    DB-9: 2 =DB-25:02
    DB-9: 3 =DB-25:03
    DB-9: 4 =DB-25:06
    DB-9: 4 =DB-25:08
    DB-9: 5 =DB-25:07
    DB-9: 6 =DB-9:1=DB-25:20
    DB-9: 7 =DB-25:04
    DB-9: 8 =DB-25:04
    DB-9: 9 nc.
    Serial communication setting You will find in parameters. Pay attention, if there are separate settings for punch and for read port.
    Try with small text (let's say, two lines) transfer from OSP to PC and describe the result:
    1. communication time. Does file transfer starts instantly after command?
    2. initial handshake and LFCR. Does next line of transfer appears instantly after first line (file name)?
    3. Check sum, packet size. Are all characters transfered properly? What about capital/ small letters?
    4. communication errors - program on PC side messages, wrong letters, missing symbols and so
    5. OSP error message. Is file transfered from OSP without warnings?
    6. Does PC program understands file end the same time when transfer from OSP ends?
    These answers will help to diagnose the communication problem
  1. Okuma MC-5VA ,OSP7000M,subprograms
    By tim shanahan in forum Okuma
    Last Post: 08-19-2015, 08:35 AM
  2. Mori Seiki SL253 RS232 setup
    By nedramsay in forum Mori Seiki lathes
    Last Post: 03-04-2014, 04:54 PM
  3. Centurion IV rs232 setup
    By ozturbo in forum Milltronics
    Last Post: 05-05-2009, 03:02 PM
  4. Hyundia Himac V-100 Rs232 setup
    By cjels in forum Hyundai Kia
    Last Post: 02-03-2009, 11:44 AM
  5. DPRNT on OSP7000M/OSP700M?
    By marcwdci in forum Okuma
    Last Post: 11-26-2007, 06:13 PM
