I finally finished my high tension power drawbar based on Hoss's design (Thanks Hoss!), but I changed his design so that it works using a single stage 3" air cylinder instead of a multistage type. I simply got tired of waiting for one to go on sale on ebay and didn't want to make my own since I had already sunk money on a 3" and 4" cylinder. I had hoped that the 4in cylinder could do the job using Hoss's LD drawbar but I kept getting pullout whenever I pushed the feed/speed too high so it was time to upgrade to the high tension version.
Attachment 236690Attachment 236692
I had some trouble with the Mark-I in a couple of areas. I had to reinforce the shoulder bolts to prevent them from bending and extended the shoulder bolt guide on the lift plate to keep it from tilting. I didn't have the right sized reamer for a sliding fit on the shoulder bolt so there was too much play in that area. The extended shaft around the shoulder bolt helped reduce the amount of tilt on the lift plate.
With the 3" cylinder I get ~2400 lbs force @ 120 PSI and that would go up to ~4300 lbs with the 4" cylinder! So far I've had no pullout using the 3" cylinder. It's soo great to be able to push my feeds/speeds now and not worry about pullout until I go too far and stall the motor...and we all know how that story goes, upgrade stock motor, add belt drive, etc. endless upgrades!
Here it is in action. Sorry, I don't have a video camera.
Attachment 236694Attachment 236696
I hope this gives you guys some ideas for making your own high tension drawbar, but if I had to do it all again, I would machine the lift plate out of a single piece of metal, use a proper sized reamer for the shoulder bolt and make the air cylinder side brackets part of the base legs that hold the shoulder bolts.
