Originally Posted by
mactec54
If you look at any CNC router just as a machine it has normally 3 Axis X Y Z, with a scroll saw you have the Z axis which is the cutting blade so the X and Y Axis would move around the Scroll saw Blade giving you 2 Axis of movement X and Y which is all that is needed to do your profiles around any shape
Your part that you where cutting would have to be suspended over a gap in the table cut area so the Blade could cut through the part and not the table
What's the max dimensions of parts you want to cut, this would determine the Table design
