587,787 active members*
3,370 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > X axis torque alarm on Takisawa Lathe
    Jan 2008
    282
    Recently I have been getting an X axis torque alarm on my Takisawa EX-108. I think it is due to the fact I let the coolant run down and get sticky. Any ideas of what else would cause this? I really need to get my projects going.
    Ardis
    Jan 2008
    282
    Smile
    I went in with a scraper and cleaned under the rubber dams on X Axis then hit with a jet of water on the hose. This seemed to have worked at least for awhile. After gentle, slow manipulation of the X-axis, I was able to move around and am now working again.
    24220
    Give the ways a good coat of waylube oil. Vactra2 or?
    Including the ballscrew, if you can see it.
    Al.
    Albert E.
    Jan 2008
    282
    Thank you, Al.
    I had already gone in and looked at the ways and ballscrew a couple weeks ago and lubed them. At this point I am convinced that the problem lies in the fact I let the coolant get so low. (Not enough information when I started learning this machine regarding the coolant tank and how it worked.) When I started refilling the coolant tank yesterday, I put in almost the same amount of liquid that the tank holds. I am going to continue to run the machine and try to build up the "slickness" factor.
  1. Takisawa CNC Lathe Communication Problem
    By Masood in forum DNC Problems and Solutions
    Last Post: 06-26-2011, 03:40 PM
  2. Takisawa Lathe-saving program to computer?
    By KCA324 in forum Controller & Computer Solutions
    Last Post: 07-06-2009, 03:41 PM
  3. Fanuc 0T-C Takisawa Lathe
    By Dave1 in forum Fanuc
    Last Post: 06-13-2007, 02:30 PM
  4. Takisawa Tw-20, CNC lathe
    By Masood in forum Mini Lathe
    Last Post: 09-22-2006, 07:35 AM
  5. Takisawa TC-2 Lathe
    By kayleesdad in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-10-2005, 08:37 PM
