Does anybody know this error message?
NC-error 2670
SPS time out
Kind regards
Axel
NC-error 2670
SPS time out
Kind regards
Axel
I have a similar problem with the Bosch CC 300 M Wanderer. Does anybody know the solution???
Hey Alex, NC error 2670 (PC TIME BARRIER) Could be different things....What machine are you using with this controller?
Causes may be:
1. Check if SPS is running
2. Is switch Edit/Monitor on RAM Board in Monitor position?
3. Battery power loss could also be the case.. Check all your batteries
4. Did you check your connection cables? between NC and SPS?
5. Is the Ausg. Sperren (Clear Output) switch on the ZE Board in the UP position?
Let me know if after this you still have the problem..
Regards..
Mak
