Have a Fanuc 6T on an old Hitachi Seike lathe. I had to reinitialize the bubble memory board the other day and then reset the parameters and settings. Afterwards everything looks right except when i home the machine out on X axis it gives up a 212 alarm "has entered the forbidden zone of stroke limit". It moves away from home position fine, and when i set it to home and try to home it moves to the point where it slows down and just as it would normally stop at home and home out it throws up the alarm. Z axis does exactly the same thing but gives a different alarm number.
I set all soft limit parameters to 99999999 and -99999999 and it still does it. No matter what i set the soft limits to nothing changes. What am i missing?
