588,285 active members*
5,221 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Selecting a @$#$load of Geometry that is all the same
Results 1 to 12 of 12
    Jan 2013
    263
    I have to select 140 of these ********. They're all the same. They're all on the same plane. Is there a faster way to do it than 140 clicks?
    Sep 2009
    1856
    Re: Selecting a @$#$load of Geometry that is all the same
    use a pattern it's beside setup top left
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Jan 2013
    263
    pattern is just for doing the same operations on multiple pieces right? that would reduce my click count to 14, but I'm still wondering if there's a way to select all similar shapes or something.
    Nov 2016
    28
    Try changing the view to a side and box select from bottom left to top right (this will only select everything that is completely inside the box). conversely, box selecting from the top right to the bottom left will select everything inside the box and touching the lines of the box. Might work.
    Jan 2013
    263
    I used to do that in Sprutcam, but the only selection method they seem to allow when selecting geometry for a CAM operation is the paint method for some reason.
    Feb 2009
    311
    I think a pattern is going to be your best bet here.
    C|
    Sep 2009
    1856
    I asked on the forum about the selection tool, Nup does not exist.
    I am going to do a ideastation idea for this it would be handy in some case's.
    [SIGPIC][/SIGPIC]
    Dec 2013
    5722
    One thing that I do is put features that I need to select as a group on their own layers. That way you can turn the other features off and grab only the ones you want with a bounding box.
    Aug 2009
    294
    I'm assuming these cutouts and both patrts are the same? If so, why would it be 14 clicks? It looks like one click for your first part at G54 with a pattern, and zero clicks if you use a G55 for the second part. Forgive me if I'm over simplifying it, but I'm only going by your picture.
    Jan 2013
    263
    There's no question that for this simple part, a cam pattern can be used.
    I must have either missed Jim's suggestion or didn't understand it at first, but that's what makes the most sense as a workaround. Correct me if I'm wrong, but I don't think fusion has layers, but if I isolated those parts to their own sketch, I could probably select them all by selecting the sketch. That won't work if they're faces, but curves, perhaps.
    Sep 2009
    1856
    You just make BS layers, sketch what ever in one file sketch 2 in another so on and just rename the sketch as layer 1, 2 what ever.
    I don't think we will ever get layers we just have to make them up in different sketches or files
    [SIGPIC][/SIGPIC]
    Mar 2008
    683
    Create a sketch on the plane. Project all edges to the plane. Delete the outer lines. Pick the sketch for your geometry.
  1. Hole wizard crashing when selecting geometry in v24
    By skippyfix in forum BobCad-Cam
    Last Post: 12-20-2014, 06:18 AM
  2. V26 Selecting Geometry
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-17-2014, 02:22 AM
  3. Replies: 10
    Last Post: 03-26-2013, 08:48 PM
  4. Selecting which side of geometry to rough mill.
    By AiR_GuNNeR in forum EdgeCam
    Last Post: 10-19-2011, 12:54 AM
  5. v23 not selecting geometry
    By lynn mynatt in forum BobCad-Cam
    Last Post: 09-24-2009, 07:31 PM
