588,261 active members*
4,560 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Replacement balls for out of production hiwin carriages (LGH15)
    May 2013
    12
    I bought a used CNC fabric cutter (Blackmann and White Genesis 2100) that had been disassembled and put into storage. Unfortunately, when the seller pulled the y assembly off the frame they didn't slot the little plastic things into the bearing carriages to stop the balls falling out so a loads of them are missing. I want to replace the balls in the existing carriages as Hiwin don't make them anymore (nor can I find replacements) and if I changed to their newer carriages then I'd also have to buy new rails to replace the existing ones. Does anyone know if/where I might be able to buy replacement LGH15 balls (or carriages) and/or if the balls in their in production equivalent (HG'x'-15) would fit these old ones?
    Jun 2010
    4262
    Re: Replacement balls for out of production hiwin carriages (LGH15)
    Mic some of the existing balls and then search the web (& eBay). You can buy replacement balls in very fine size steps.
    Cheers
    Roger
  1. Lets do some trading? Hiwin 30mm for Hiwin 25mm
    By hacker7 in forum Open Source CNC Machine Designs
    Last Post: 06-22-2013, 06:51 PM
  2. cncrouterparts.com carriages on MDF
    By Drools in forum Joes CNC Model 2006
    Last Post: 09-27-2010, 10:05 PM
  3. THK rsr 15 rails and carriages
    By endgrainguy in forum Linear and Rotary Motion
    Last Post: 03-24-2008, 03:47 PM
  4. NSK Rails - Replacement balls and spacers?
    By Lionclaw in forum Linear and Rotary Motion
    Last Post: 02-24-2007, 08:36 PM
