588,380 active members*
4,995 visitors online*
    Oct 2004
    D&M Computing CNC 9 Lathe Info???
    Hello,
    I recently aquired a CNC Lathe, manufactured by D&M Computing. This is a somewhat small lathe, with a 4" chuck, around 15-16" between centers.
    This is a floor model machine, with a full enclosure and sliding door.
    Can anyone direct me to where I can get some information on this machine, and/or the process to get this machine running. I assume I need to obtain some software, and do some type of retrofitting to get it compatible with a the pc?
    I have seen some of the smaller machines from D&M on ebay, the CNC 6 Lathe, which is a desktop model.
    Thanks in advance for any info -
    -Tim
    Oct 2004
    here is about the only web page that I found with any info on it
    http://www.doubleduck.com/DandM.html
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Are ballscrews necessary for PRECISE work on a cnc lathe?
    By daytrader in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2005, 07:34 PM
  3. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
  4. Need Info. To Convert Atlas/Sears Lathe To CNC
    By creative_mind in forum Uncategorised MetalWorking Machines
    Last Post: 02-12-2004, 07:31 PM
  5. Taig lathe Threading and CNC questions
    By anoel in forum Mini Lathe
    Last Post: 01-12-2004, 10:43 PM
