587,997 active members*
1,951 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > OUtlets in back of machine stopped working
Results 1 to 7 of 7
    Sep 2011
    474
    Im not sure what happened, but when I went to plug in my coolant system none of the plugs would work. Is this a problem anyone has dealt with? Any way to fix it?
    Thanks in advance, guys!
    Oct 2013
    104
    Re: OUtlets in back of machine stopped working
    Have you checked the fuse? Its a 6A fuse for the auxiliary circuit. Don't know what kind of fuse it is, but I can think its a glass-fuse (small one).
    Oct 2013
    104
    See included image. If you have a continiuty tester, check if the fuse is broken if you can't see it with the bare eyes by testing both ends of the fuse.
    The switch can also be broken, check it the same way as you did with the fuse
    Attachment 254126
    Jun 2006
    3063
    Are you using the Tormach coolant system? If you are using something else what is the current rating for the pump?
    Mike
    Jun 2006
    2512
    If you don't know how to test the continuity of a single phase supply then best to call an electrician. Oh I wonder if the fuse has blown. Come on sunshine put your brain in gear.
    Phil
    Oct 2013
    104
    Quote Originally Posted by MichaelHenry View Post
    Mike
    I got the information by tormach, and another user on this forum from another thread in this subforum.
    Tormach confirmed that the pump is 75W.
    If thats all you have on the auxiliary power and its 115VAC you would need a 1amp fuse.
    Nov 2010
    291
    The 120 is suggested to be plugged into a GFI outlet. If so is it tripped? The outlet furthest from the column is for the coolant pump and thus controlled by cnc if i understand correctly. Does the computer power up when plugged back there?
  1. G540 stopped working
    By enricodina in forum Gecko Drives
    Last Post: 10-22-2014, 10:01 AM
  2. Replies: 0
    Last Post: 05-09-2013, 12:08 PM
  3. SX3 Stopped Working
    By mikemill in forum Syil Products
    Last Post: 01-09-2009, 04:54 PM
  4. Mach 2 just stopped working
    By mikesos1 in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2005, 04:50 AM
  5. Master5 stopped working
    By jderou in forum Mach Software (ArtSoft software)
    Last Post: 09-08-2004, 07:38 PM
