588,490 active members*
4,448 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko 540 Mach 3 Keling Steppers on a Taig
    Jul 2008
    85
    Ok got everything setup tonight and having a issue. The steppers seemed to stutter when the taig is jogged.
    it is semi smooth if mach 3 is set to 5lpi. Yet its is not smooth at all. This is the same with all 3 axis.
    I have done all the Mach 3 optimizations for windows
    I have removed the steppers from the taig and all axis turn smooth by hand
    When steppers are jogged while removed from mill problem is the same so I ruled out gib binding.
    Can anyone running this setup give a starting point for motor tuning maybe that will help get a reference where to start. Also I hooked this up to a xylotex stepper and it did the same so i doubt its a lot of bad steppers.
    Setup
    Taig Mill
    Controller Gecko 540
    PC Desktop Compac Presario Win XP Optimized for Mach 3
    Steppers Keling 282oz KL23H276-30-8B
    Power Supply Keling 48V
    Jan 2007
    467
    What are your Mach3 settings? Also, are you using the XML file from our website?
    Marcus Freimanis
    Jul 2008
    85
    Marcus
    Steppers Wired Bipolar Parallel ----- 3.3k ohm resistors used in steppers
    motor tuning this was last setting where it had least stutter in motors same in all 3 axis
    steps per 40000
    velocity 5
    acceleration 2
    step pulse 2
    dir pulse 1
    This is on a rev 4 controller Gecko just replaced. Never had a chance to use other rev controller due to motor cycle accident so its not like it worked now it does not this is a new setup
    Mach3 "ports and pins": Set step "active high".
    Mach3 "motor tuning": Set step pulse width to "2" microseconds.
    In BIOS: Set parallel port to "EPP".
    Mariss
    Jul 2008
    85
    Mariss Thank You For your help I PMed you
  1. Keling servo as Taig spindle motor replacement?
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 08-18-2009, 11:41 AM
  2. 4 Wire Keling Steppers Confusion
    By n1bpd in forum Automation Technology Products
    Last Post: 09-05-2008, 06:58 PM
  3. Wiring keling steppers to FET 3 board..HELP
    By Jackflash65 in forum Automation Technology Products
    Last Post: 04-13-2008, 03:38 PM
  4. Keling Steppers Price Increase ???
    By Eurisko in forum Automation Technology Products
    Last Post: 02-21-2008, 12:55 AM
