588,411 active members*
5,148 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Using Diamond Cutters to get optical finish
    Oct 2008
    Anybody have any knowledge or tips about using diamond edged cutters to achieve smooth polished finish when cutting optical parts like acrylic custom lenses. I keep hearing this can be done but our experience shows a "better" finish but not one that can be used without hand polishing.
    Sep 2007
    100
    I use diamond cutters to mill glass on a cnc (HAAS). Anything that requires an optical finish is polished on polishing machines.
    I am open to suggestions, if there are any.
    Mar 2008
    683
    Acrylic lenses
    Quote Originally Posted by cncron View Post
    There are 3 edged cutters I use from Onsrud that leave an excellent finish on cutting acrylic. There are a couple ways to get a nice polish on the cut edges. One is buffing and the other is use a hydrogen oxygen flame from a jewelers torch (available at harbor freight) and flame polish the edges. It's tricky but you'll get the hang of it. If they edges are rough you'll have to sand it first. If you are face milling acrylic you'll just have to get the best you can with your endmills, sand, and buff / flame polish. I don't think diamond bits are the way to go with acrylic. Acrylic will just load up the cutter and melt the acrylic.
    Nov 2005
    1468
    Not unless you use Single Point Diamond Turning like wot I do.
    You need:
    1) A diamond turning lathe, vibration isolated and temeprature controlled with air bearing spindle and slideways (optical encoders for linear positioning)
    2) MONOCRYSTALINE gem quality diamonds (see Contour Fine Tooling)
    3) For Acrylic- zero degree top rake and 15 deg front clearance on the tool.
    4) CAST acrylic (not extruded).
    5) Correct depth of cuts and feedrates.
    6) Spray coolant optional. personaly I just use air.
    Here's some I made earlier (no post polishing, straight off the lathe)
    [Edit] Oh, these tools cost about 300 to 700 quid each depending on spec. If you use it on a normal machine you WILL wreck the tool. If you set the tool above part centre or past centre you WILL wreck the tool. If you touch the diamond cutting edge you WILL wreck the tool. Sometimes they can be resharpened at about 30 quid each and 3 week lead time.[/Edit]
    If you want more info lemme know.
    Attached Thumbnails Attached Thumbnails MRI_0004.jpg   Img3_0002.jpg   Img2_0001.jpg   Img_0002.jpg
    I love deadlines- I like the whooshing sound they make as they fly by.
  1. Abrasives: CBN is not Diamond!
    By widgitmaster in forum MetalWork Discussion
    Last Post: 09-01-2010, 12:40 PM
  2. Zinc-Plated Finish vs plain finish for threaded rod?
    By Almaz in forum DIY CNC Router Table Machines
    Last Post: 10-21-2008, 08:39 PM
  3. abrasize diamond coating
    By bigbobr in forum Material Machining Solutions
    Last Post: 05-15-2008, 07:17 PM
  4. diamond pin
    By fpworks in forum MetalWork Discussion
    Last Post: 09-18-2006, 05:52 PM
  5. Dressing diamond cup wheels
    By cncorbust in forum MetalWork Discussion
    Last Post: 07-01-2006, 01:00 PM
