Are you using the curves as a region curve? Maybe I'm misunderstanding what you are trying to do, but if you are using the half-oval as a region curve to control the cutter, make sure the half-oval is a closed solid. If you've trimmed it with a line and haven't joined it, it will not select.
Like Svenakela mentioned, post an image it helps a lot. Like the saying goes, "a picture speaks a thousand words".
Dan
