586,121 active members*
3,121 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD v24 t slot milling
Results 1 to 5 of 5
    Oct 2010
    1189
    Hi
    I am quite ok with BobCAD so far but
    For my turret i do need t slot s Milled. So First the "valley " andere then verry slow the slot.
    I am of course not drawing with BobCAD i use turbocad.
    But how to tackle that issue? What to draw? How to tell BobCAD
    It is an 8 Tool turret and i want to simply clamp the steel direct to the bed so the cnc is required to calculate the not even path s
    In advance
    Thx Thomas
    Oct 2006
    173
    If this is on a mill use a single line and a profile cut.
    You mention turret though .. If this is a lathe BobCAD does not currently do mill/turn.
    Oct 2010
    1189
    T-Slot
    Hi ,
    thank you for the fast reply it is clear i need to draw an extra layer and do 2d milling my question was if there is any support of the software i might not be aware of ,..
    No sorry i was not clear enough i want to build an turret for my cnc lathe.
    And therefore i need to mill. My design is based inspired of
    http://www.joshupdyke.net/tiki-downl...ay&x=800&y=353
    and i want for better force transmission an t-slot design ,..
    probably the reason why they did not is because of complicated manufacturing
    thanks a lot
    thomas
    Feb 2008
    217
    Quote Originally Posted by Tkamsker View Post
    Thx Thomas
    Hi Thomas,
    Just curious, why not draw in BobCAD ? I find the drawing tools to be very easy.
    As for how to do the T slots I would draw a line straight down the center of the slot and then add parallel lines with a fillet on the end or a circle which you will then break and trim. I too am interested in a turret of the design you show in the attachment.
    Draw the slot once in detail and then use the rotate tool to create the other slots.
    Oct 2010
    1189
    Quote Originally Posted by Joe S.
    Hi Thomas,
    Hi
    I use turbocad and for me it is verry Handy.
    I tried the CAD of BobCAD for me it is not intuitive and ui wise not verry economic but as we say " Gusto und watschen sind verschieden " wich means that tastes are different
    The atc turret is for my Klippfeld lathe and is controlled by arduino and 2 steppers No pressurized air is needed and best you can use it Manual or by emc for instance i work on an arduino based handwheel wich is based on Mr sansbury95 s work. And this i recycle for the turret.
    So it you have intrest let me know
    Thx
    Tk
  1. Slot Milling on a Lathe ?'s
    By Crashmaster in forum MetalWork Discussion
    Last Post: 07-15-2010, 03:23 PM
  2. Milling Slot in 1010
    By gpraceman in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 06-24-2010, 01:41 PM
  3. Milling slot , but not smooth
    By Tony Chen in forum Community Club House
    Last Post: 06-23-2010, 06:23 PM
  4. Milling Slot in Aluminum
    By gpraceman in forum Community Club House
    Last Post: 06-20-2010, 12:53 AM
  5. Helical milling a slot
    By kevinheez in forum Surfcam
    Last Post: 05-02-2008, 01:14 PM
