I'm new with this stuff so..
I connected everything and started testing with Mach3..
The steppers run fine at about max 500rpm, but stall if I try to go any faster (no load attached to the steppers).
I *think* I have the steppers wired correctly, but I'm not 100% sure. (Bipolar parallel, steppers has 8 wires).
The drivers are set to 3A, 48V. The steppers are rated 3A/phase.
Strange to me is, if I lower the amps to 0.7A I can run the steppers at approx 1000rpm..
Is this normal? Or do I have a problem somewhere? I thought more than 500rpm should be possible..
Thanks!
