587,098 active members*
6,099 visitors online*
    Mar 2005
    271
    CNC Plasma Build Question
    Well I'm going to build a cnc plasma cutter. I have everything I need except the steel and was wondering what size of square tube I should use. It will be 5 x 5 table and I want to make it out of 2x2x.125 wall square tube. My question is do you guys think that the .125 wall will be heavy enough or should I go with something thicker.
    Any help would be great.
    Thanks Mike
    Jun 2009
    45
    I think it is heavy enough, but I am from Europe
    In my opinion the rigidity of your gantry will make the difference; more than the weight or your table frame
    Oct 2005
    328
    I built my existing 2.5' x 2.5' table out of 1.5"x2.5"x14ga tubing, and it's plenty strong. For a plasma cutter, the main things to consider are really the ability of the machine to keep the axes perpendicular. As long as that is good and the table isn't able to rack, it should be fine. My rev. 2 table being built now uses 1.5"x1.5"x14ga and I don't expect any problems. If you are using THC, even the torch height doesn't have to be perfect across the table, and besides, the metal is going to move when it's hot anyway.
    So, I would guess that what you have will be fine. If you can flex it a lot, maybe just add some gussets in the corners.
    Just my 1.7¢.
    Dave
  1. My first plasma build :)
    By Sperstad in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-01-2012, 09:34 PM
  2. 2.5X1.5m (8X5') plasma build
    By tommylight in forum Waterjet General Topics
    Last Post: 04-11-2011, 11:14 PM
  3. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  4. 4 X 8 CNC Plasma Build
    By vishnu in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-07-2011, 10:31 AM
