587,999 active members*
1,791 visitors online*
    Feb 2007
    27
    Plasma+water table on casters?
    I have 6 1500lb rated castors I was thinking about putting on the bottom of the table to make it slightly mobile... basically roll from one bay of the garage to the other. I see a lot of folks using leveling feet or just steel legs. Is there some big disadvantage to having it on castors? Its gonna be a dam heavy table so the movement of the Y axis shouldnt really move the table around.
    I need your wisdom..
    DeviousMW
    Mar 2006
    759
    When you have your machine on casters, the inertia of the gantry moving around can shift the table on the casters, at least during rapid movements of a heavy gantry. This can also shift your workpiece.
    Casters are not a bad thing, but make sure you can retract them or lift the table off the casters.
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
  1. Water transfer techniques for water table?
    By Knut in forum Waterjet General Topics
    Last Post: 02-02-2007, 04:52 PM
  2. plasma or water jet???
    By hutch82 in forum Waterjet General Topics
    Last Post: 01-30-2007, 03:40 AM
  3. Plasma/water/lazer cutting
    By ty1295 in forum Employment Opportunity
    Last Post: 10-15-2006, 01:36 AM
  4. plasma water tank
    By snaggletto in forum Waterjet General Topics
    Last Post: 06-17-2006, 01:04 PM
  5. NEED 1/4" plate cut via plasma/water/etc.
    Last Post: 04-20-2006, 02:29 PM
