588,201 active members*
5,109 visitors online*
    Jan 2013
    X axis randomly tracks wrong way
    First post on this forum so I would like to say hello and thanks for a great forum and all the good advice and comments to be found here. Hopefully someone can help me with my problem and please bear with me I am new to the world of CNC.
    Have recently brought a Chinese 6040 unit from eBay that worked well for the first week or so, then the X axis has randomly starts tracking left -X when it should be tracking right +X. The first time I noticed this fault I was jogging the head to the right but it tracked left, stopped jogging and retried and it worked in the correct sense. It did this once or twice at random, I checked all the plugs etc then while milling a part it randomly tracked left cutting a grove right out of the part before I could stop it! Switched stepper motor driver with the Y axis but problem still occurred on X axis, having read though this forum and other information I replaced all the wiring to the motors and earth bonded everything. The first time I turned it back on it did it again! When the fault occurs Mach 3 shows the X axis increasing so I assumed it was not a software fault? Any ideas as to what I should try next very gratefully received.
    Jan 2013
    Found the cause of the problem and now fix.
    Feb 2005
    85
    Quote Originally Posted by Shadowfax View Post
    Please share what problems you found.
    Charles
  1. Axis going the wrong way!!
    By aadonline in forum Fanuc
    Last Post: 11-15-2017, 01:35 PM
  2. X & Y axis going the wrong way
    By utengineer04 in forum Mastercam
    Last Post: 04-20-2011, 07:51 PM
  3. X-axis randomly scales to -1
    By sharbin in forum Mach Mill
    Last Post: 03-04-2011, 03:05 AM
  4. Z axis randomly traveled .150 for no reason
    By Gun-Machine in forum Tormach Personal CNC Mill
    Last Post: 01-11-2011, 11:38 AM
  5. Z axis randomly plunging
    By Don-in-Japan in forum Benchtop Machines
    Last Post: 05-31-2009, 07:58 PM
