The Continuous torque is 11.25 lb-in at 4.76amps. This is virtually from 0 to 3000rpm.
This is the number you should be looking at, the peak should never be used as a design criteria as you should not go into this area if at all possible, if the peak current is achieved for any lengthy time duration it usually means you have lost control and motor damage can occur.
Al.
Albert E.
