587,998 active members*
1,748 visitors online*
    Oct 2007
    12
    c axis work shift
    I'm using a 21I controller on a lathe with live tooling.
    We stick our z axis work shift in some of our codes (parameter #2601). I was wondering if there is a similar parameter for a c - axis work shift?
    Thanks for any help.
    Dan
    Aug 2006
    98
    Dan,
    1) C-Axis is the living tool or the spindle ???
    2) Using system variable #2601 you modify only the tool geometry to shift the Z axis.
    Daniel
    Oct 2007
    12
    Parameter number #2601 in this control is listed as a workpiece coordinate shift. In the operators manual it is listed like this:
    Workpiece coordinate system shift amount:
    x axis: #2501
    z axis #2601
    When I put a value for #2601 it is inserted into the z axis workshift.
    I'm looking for a similar parameter number for the c axis.
    Dan
    Jun 2008
    1511
    In your work coordinate does it show "C"
    X axis
    Z axis
    C axis??
    If it is listed they usually go in order. Try #2701.
    Or does C show up in your woork coordinates?
    An example of your work coordinates lets say G55
    X=#5221
    Y=#5222
    Z=#5223
    C=#5224
    This will depend on how many coordinate axis you have listed.
    Stevo
  1. Setting Z axis with G92 work shift
    By venomgrrrl in forum Fanuc
    Last Post: 12-03-2007, 06:02 PM
  2. Automatic work shift on lathe, is it possible?
    By DonutSlayer in forum G-Code Programing
    Last Post: 05-28-2007, 05:48 PM
  3. How do i get my C axis to work?
    By Deejay in forum MetalWork Discussion
    Last Post: 01-11-2007, 05:49 PM
  4. 4 Axis Cam Work
    By Mark Mathews in forum Employment Opportunity
    Last Post: 10-07-2006, 06:25 PM
  5. 5th even 6th axis? how does it work
    By ToMMY2ooo in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2004, 09:58 PM
