588,032 active members*
4,232 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bisect lines BobCad Cam V24
    Apr 2007
    42
    Hi.
    I am making a part with a lot of inside corners and i am using the Bisect line function in the 2D profiling function in BobCad Cam to relive the corners. But on squares it does not seem to work. It only takes 3 of the 4 corners evry time. See the picture:
    As you can see the bottom left corner is not relived like the others.
    Is there any fix for this? I don't really want to make the relive cuts manually by putting a circle in every corner when there is a function already in the program that is suppose to do this for me.
    Apr 2009
    3376
    Re: Bisect lines BobCad Cam V24
    You cannot have your chain start in the corner.For example,,if you are doing a square,take one of the lines and break in half.Start your chain from there and all corners will bisect.
    Let me know if you need more explanation.I can video if needed.
    Dec 2008
    4548
    Yeah, you can just use the start point in the feature and right click-modify and be sure to set it at a middle point of one of the sides.
    Apr 2007
    42
    Ok. Where do i select the start point?
    EDIT: Never mind, i found out.
    Tank you of the help, that solved my problem.
  1. Replies: 9
    Last Post: 01-11-2014, 11:04 PM
  2. Replies: 2
    Last Post: 08-26-2013, 07:37 AM
  3. Bisect Inside Corner problem
    By tlharris in forum BobCad-Cam
    Last Post: 07-28-2013, 04:16 PM
  4. Dashed Lines?? Sames lines to still show dashed in different scaled viewports?
    By coykiesaol in forum Uncategorised CAD Discussion
    Last Post: 12-29-2010, 04:38 PM
  5. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
