I'm using emc2 with my own built CNC and have the following problem:
I programmed a rectangle. When milling, the edges are no edges any more! the mill takes a shortcut and the edges are rounded. The mill does not break and drives around the edge with more or less full speed. I tried changing several values (accel, maax accel, stepgen max accel, output scale = input scale, Ferror...) but I don't get rid of this problem. programming lower speed is one solution which makes it better but tell the post to drive edges slower...
Any ideas?
regards Oliver
