587,243 active members*
3,253 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc 18t parameters editting peocedure
    Sep 2008
    9
    Angry fanuc 18t parameters editting peocedure
    Dear all
    we have JHONFORD CNC lathe with 18T Controller. we wanted to change some softlimt parametrs. please give me the procedurs to edit the parameters.
    it will be a great help.
    regards
    reddy
    Jun 2008
    1511
    You will have to set your PWE. Go to the offset/settings key and put 1 in the PWE to enable it. Attached is a sheet that shows how to do it.
    Parameters 1320 are the softlimits for the + direction and 1321 is the - direction.
    Be careful when adjusting these. I typically set mine about 3mm past the reference position. Most ball screws are metric so the value in this parameter will be in metric to the 3rd decimal. So as an example by setting 5000 it will read it as 5.000mm. If you set it to 5 it will read it as .005mm.
    Why do they need adjustments??
    Stevo
    Attached Files Attached Files
    Sep 2008
    9
    Thank you very much for your reply.
    I will Adjust the values and reply to you
    Regards
    reddy
    Jun 2008
    1511
    Your welcome.
    Stevo
  1. Help I need Fanuc 3tf parameters
    By lloydy304 in forum Fanuc
    Last Post: 09-28-2008, 10:48 PM
  2. Fanuc 21T parameters
    By pieface in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-12-2008, 12:16 AM
  3. NEED FANUC 18-TB PARAMETERS
    By icnc in forum Fanuc
    Last Post: 11-21-2007, 04:56 PM
  4. Fanuc 0-T parameters
    By BigGrilla in forum Fanuc
    Last Post: 09-27-2007, 01:43 AM
  5. Fanuc 18T - Parameters
    By pinguS in forum Fanuc
    Last Post: 04-12-2006, 12:20 AM
