588,442 active members*
5,449 visitors online*
    Nov 2007
    197
    pocket milling help
    i'm machining a rather large enclosure from solid walnut. The outside gets profiled with a 1/2" diameter, 2" tall cutter - the enclosure itself is 1.5" tall
    there are then various internal routings to allow room for the components that go inside.
    i'm having some trouble with one pocket that is 1 1/8" deep. I'm taking small depth cuts, about .09". The issue i'm having is the bit is not always cutting at the 1 1/8" depth. 2 out of the 4 walls are already relieved down, so the depth there is only about .3"
    When i get into the corner where the depth on both sides is 1 1/8", the bit wants to pull into the work surface. Not much, but its enough to leave a mark. Last night it was enough to crack the wood (must have already been weak there)
    Mind you, this is being done on a home built cnc. Not quite a Haas, but not entry level either
    i've tried slowing down the feedrate. should i also slow down the cutter? The pocket is small (1.5" x 4") so i dont mind slowing things down if that would be the way to go
    I guess ultimately having a corner radius that is larger than the cutter could help too - but i'm not sure thats possible. unless it was just slightly larger
    May 2007
    781
    You can get carbide end mills 1/4 diameter that will go 1.125 deep.
    Sounds like you are conventional milling into the corners and as it goes into the corner it is taking a heaviear cut and pushing the tool into the side more.
    You may want to try roughing with a climb milling cut.
    Nov 2007
    197
    yeah part of the problem is i'm trying to do as much as possible with one cutter
    i'm going to add in a .05" radius into the corners to minimize the tool load and see how that goes tonight
  1. Pocket Milling HELP!
    By 12learn in forum MetalWork Discussion
    Last Post: 10-08-2009, 02:15 AM
  2. Pocket milling
    By orionstarman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-08-2008, 12:26 AM
  3. pocket milling
    By CNC stud in forum MetalWork Discussion
    Last Post: 03-26-2008, 09:33 PM
  4. Problem with pocket milling...
    By Driftwood in forum GibbsCAM
    Last Post: 09-04-2006, 04:25 AM
  5. How to get polished look when milling pocket
    By originator in forum MetalWork Discussion
    Last Post: 08-04-2006, 02:47 AM
